Who plans on towing with their Hyundai Palisade?
  • Yes - Large Trailer with brake controller
    Votes: 26 47.3%
  • Yes - Small Trailer
    Votes: 26 47.3%
  • No
    Votes: 3 5.5%
  • Total voters
    55
alfman
Texas
#21
Ditto on it being factory installation. I had already purchased the factory tow hitch and wiring harness from the dealer for about $580 total. I have an appointment this Tuesday to have it installed along with a 7-pin controller harness and P3 Tekonsha brake controller. They need to run power and from the battery and brake wire to brand new 7-pin adaptor. The factory only comes with a 4-pin.
Once it gets installed, can you post a picture of the installed tow hitch?
I'm trying to get a better feel for how far below the rear bumper the hitch will be (I have a steep driveway at home/work).
Thanks.
Northern California
#23
OK so finished having the install done at the trailer shop. Had them install the following:
  • Palisade factory tow hitch
  • Factory 4-pin wiring harness
  • P3 Tekonsha brake controller
  • Dedicated power and brake controller line from cabin/battery to 7-pin adaptor
  • 7-pin adaptor that they had in stock that mounted right to the factory tow hitch
A nice touch is the tow hitch includes a Hyundai-logo branded cover. Here are the pics:
View attachment 723 View attachment 724 View attachment 725 View attachment 726 View attachment 727
Wow that’s a really clean install of the 7-pin and brake controller.
alfman
Texas
#27
Thanks for the pictures!
Hyundai
#28
@Mikeg112 can you measure how much clearance there are to to the bottom of the hitch? We have a steep driveway I think it'll scrape. Also thanks for the photos.
Just wish it was more integrated into the bumper like the Telluride.
Northern California
#29
Thanks for the photos @Mikeg112. How much did the shop charge to install the hitch and wiring?
Sure, it was $100 to install the hitch, and $250 for the 7-pin wiring. They ended up having to run a separate line from the battery to the hitch, this allows me to be able to power the electric brakes and charge the battery on the travel trailer. A 4-pin connector only had a 4-5 amp max so it takes that load completely off the left-right turn signal lights.
Northern California
#30
Here are the measurements on my flat driveway:
  1. Floor to bottom of hitch: 10 inches
  2. Floor to top of hitch tube: 12 1/3 inches
I ended up watching this video on hitch rise/drop, and here are my calculations, let me know if this seems right:
  • Bottom of trailer ball hitch mount from floor: 20.5 inches
  • Floor to top of hitch tube: 12 1/3 inches
  • Difference: +8.2 inches or an 8" rise
Next plan is to order an 8" riser, hoping that makes sense.
P
Cincinnati, OH, USA
Thread Starter #32
Great info
Northern California
#33
Just a heads up everyone, planning on taking the trailer out this weekend for the palisades first road trip, it’s a local campground only an hour away. I’ll post photos and a quick review on how it performs.
Northern California
#36
EB67DB02-AD45-41AF-842B-6A40216A43A7.jpeg 71EF6F22-1BF0-4485-948E-9C937D7AA303.jpeg 6711E375-E2B2-4681-A1B7-6CD8601F9276.jpeg
After renting a truck for past six months so happy to finally have a tow vehicle that can handle our 4,000 trailer. Took it for a brief test drive last night, here’s my initial feedback:
The palisade did sag a bit initially once you hitch up. But the self-leveling takes about 3-4 miles to adjust due to the nature of the self-leveling shocks. I probably have about a 1-inch drop in the rear axle, will drive an hour to our camping spot and see if I need a weight distribution/sway control hitch over the weekend.
Drive: as a driver you do notice you’re towing, but leaving in comfort mode it almost auto-adjusts the rpms to match the uphill and towing. Surprisingly my wife in the passenger seat didn’t even notice that we were towing! I tried sport mode but was revving a little too high for my preference, so I leave in smart mode for now.
Northern Michigan
#38
The one I just bought (& apparently all of the Palisades) already has the transmission cooler & is "wiring harness ready" - that was standard on the sticker. The "factory" hitch is bolted on by the dealer. Seems very odd to me...
The Villages, FL, USA
#39
I just took delivery on a AWD Limited Palisade yesterday and have to get a hitch and seven pin connector installed for trailer breaks. Would you mind posting some pictures of your installation and sharing your experience with the 7 pin. Did you have to pull in 12v to the dash and a cable to the 7 pin to power the trailer brakes, or might that be pre wired like most other mid sized SUVs?🤞
#40
Bruce, you may not have noticed the second page in this thread. He did post pictures.
