Air intake?
itnetpro
Glenmoore, PA
2026 Hyundai Palisade
We just purchased a new 2026 Palisade Calligraphy. Below the bumper on the driver side, I noticed what appears to be an open flap or vent. The passenger side is closed. I asked the salesman and he said that's normal to cool the battery. Well, it never closes and the other vent always remains open. Is his information accurate?
Nolenski
South Park
2023 Calligraphy
And you trust ANY salesperson... Really? Did you check with Service?
Those are active vents to allow the engine cooling to work efficiently.
I
itnetpro
Glenmoore, PA
Nope, did my own investigation. The one on the driver side definitely is operated by a powered gear. When I force it closed, I can hear the gears. After driving, it just re-opens and seems to stay open. At least after I park and look again. The passenger side can also be adjusted but it’s manual.
I leveraged Chat GTP to also confirm. At first it said there was an active vent but I asked it to provide its source and it displayed a part diagram related to the front bumper.
I have yet to find any criteria the system uses to open and close but I was able to confirm that it prefers open always when the engine is off. even in the freezing temperatures we are experiencing here in SE PA.
seems poorly thought out and thrown in late in design to address a potential problem if you ask me.
Whatever the case, this is our first Hyundai and we love it! I can afford a higher end BMW X7 but the refinement, luxury and value in the Palisade, gives me no reason to even consider something more expensive.
John
Nolenski
South Park
2023 Calligraphy
I have a 23 Palisade Calligraphy (my first ever Hyundai), and it has been totally trouble-free. I also have a 24 RX350h, and the technology in the Palisade is far better than in the higher-priced TWO-row 'luxury' Lexus. I'm looking at the 2026 Palisade Hybrid Calligraphy and comparing it to the Lexus TX 500h F-Sport. I've driven both. Once again, the Palisade wins from a technology perspective, and the ride of both vehicles is comparable. But, with a nearly $20k price difference, it's hard to choose the Lexus, ultimately get less of a vehicle and paying significantly more simply for the prestige badge. And those electronic doors on a Lexus have already been troublesome - I've had 2 toddlers locked in the vehicle for over an hour in frigid weather due to a malfunction. So I don't want to go through that with another Lexus. Surprisingly, the Hyundai post-sale service has even been better than the
As for the 26 vs the 23 Palisade Calligraphy, it seems that many of the minor complaints I've had about the 23 have been addressed in the 26: hybrid option (mpg & power), smoother ride, standard tow package, upgraded audio system, and integrated dashcam. The only things they missed were 1) adding the unlock/lock to the rear passenger door handles - for a family hauler, it's inconvenient to use the front door handles just to unlock the back door to get the kiddos in the vehicle 2) adding a bit more cargo room behind the third row, 3) having the auto high beam and lane keep assist remember the last setting, rather than having to set it before each ride.
Since my 23 is still problem-free, I'm going to wait until the 27MY to see if any reliability or first-year model issues surface, such as the one you've described. I'm always cautious of first-year models for just that reason - historically, they are the most trouble-prone regardless of vehicle brand. Manufacturers typically iron out some bugs in the second and third model years. The Lexus TX is also due for a mid-model refresh in 27 with a potential additional powertrain option, so I'll revisit that as well.
As for those active vents at the bottom of the bumper, Toyota/Lexus has had those for years on their hybrids, and they have been trouble-free - It sounds like you may have some stripped gears in yours.
Swig1
Mason, OH
2026 Palisade Hybrid Caligraphy AWD
I have a 2026 Palisade Hybrid calligraphy. I believe the hybrid battery intake vent is located under the front passenger seat. Here is a photo of the intake vent next to the floor heating vents. I hope this helps.
Ontario Canada
2026 Palisade hybrid Palisade
My flaps are open every morning no matter if I have driven the car or not. I can only assume that the default setting after whatever cycle they went through is complete. This makes no sense. If you park the car outside like I do then you are just inviting any rodent, in my case squirrels, to enter and nest and chew wires. This is a software problem they could easily fix. My car sat for 2 days and I had to just start the car and they would cycle and close. The engine did not even run. So even though the engine is cold they opened up about 2 hours latter for no reason. I have written Hyundai to ask why and am awaiting their reply. I will post when I get their response.
CraigS26
Birmingham
26 Palisade Hybrid SEL Premium
Per OP itnetpro ... If a Vent is always Open ... Both surely should Close at Engine Off and Open at On. Svc should look at it.
